Mitutoyo
More Than Measurement—A Smarter Way to Ensure Plastic Bottle Quality
Precision Metrology for a Changing Plastic Bottle Industry
If you care about delivering a plastic bottle that performs flawlessly—on the production line and in the consumer’s hands—precision matters. The plastic bottle industry is rapidly evolving, with sustainability initiatives driving lightweighting and more complex packaging specifications. Quality assurance is no longer just an end-of-line checkpoint—it’s a strategic advantage that protects your brand, improves efficiency, and ensures consistent performance. That’s why precision metrology is your most reliable ally.
Why CRYSTA-Apex V for Plastic Bottles?
Unmatched Accuracy:
The CRYSTA-Apex V Series is engineered to deliver the highest precision in plastic bottle inspection. With a guaranteed maximum permissible length measurement error (E₀, MPE) of just 1.7 + 3L/1000 μm, you can ensure every thread, neck, and wall thickness measurement meets the most stringent requirements—confidently and repeatably.
Thread, Neck, and Wall Thickness Measurement Made Easy
In plastic bottle production, even the smallest dimensional deviation can create big downstream problems.
Why these features matter:
Threads & Neck Finish – Critical for leak prevention, closure torque, and compatibility with high-speed capping and filling lines.
When inaccuracies happen, you risk:
  • Costly downtime from misaligned closures
  • Seal failures that shorten shelf life
  • Incompatibility with standard closures or tamper bands
Wall Thickness – Impacts structural integrity, shelf presentation, and sustainability goals.
Dimensional verification with CRYSTA-Apex V ensures every bottle performs as intended—from the first run to the final shipment.
Sample measurement of bottle thickness
Sample measurement of bottle neck profile
Boost Throughput with Large Batch Capability
The CRYSTA-Apex V is designed to keep production moving:
  • Multiple measuring ranges support fixture arrays, multi-part setups, and rotary tables.
  • Multi-sensor support measures threads, necks, and wall thickness in a single pass.
  • Automated part programs reduce operator dependency while ensuring repeatable results.
The result? Faster inspections, fewer setups, and reduced downtime.
Quality You Can Trust—From the First Plastic Bottle to the Millionth
In a market where precision defines product performance and brand reputation, the CRYSTA-Apex V Series gives you the confidence to meet evolving sustainability and quality demands—today and for the future.
The CRYSTA-Apex V is a high-accuracy, high-speed CNC coordinate measuring machine designed for versatile dimensional and geometric tolerance measurements, offering improved productivity and enhanced visualization within a single unit.
MiCAT Planner - Measurement Program Generation Software for Coordinate Measuring Machines
MiCAT Planner automatically generates CMM measurement programs from 3D CAD model tolerance data, significantly reducing programming time and improving efficiency.
GEARPAK Express - Gear Measurement Evaluation Software for Coordinate Measuring Machines
GEARPAK Express is an intuitive software that automates gear and tolerance evaluations while delivering results without changing the CMM setup, offering greater versatility than dedicated instruments.
Mitutoyo Corporation
Privacy Policy
All rights reserved.
