Precision Machine Navigator
Measurement Solution Webinars
Introduction to Coordinate Measuring Machine: Improve inspection consistency and reduce reliance on manual measurement with shop-floor ready CMM inspection. <Duration: 11 minutes>
Labor shortages and growing inspection demands are driving the need for faster, more repeatable measurement. In this short webinar, you’ll learn how the MiSTAR 555 delivers shop-floor CMM inspection with minimal setup—reducing manual effort while improving throughput and quality assurance.
You’ll learn how CMMs can:
  • Deliver precise, repeatable results — even in harsh shop environments
  • Increase throughput through automation and minimal setup
  • Reduce human error and improve inspection consistency
  • Integrate into existing workflows — no temperature-controlled room required
  • Support both new and experienced metrology teams as inspection needs grow
Recommended for:
  • Teams facing labor shortages or rising inspection demand
  • Manufacturers struggling with inconsistent inspection results between operators
  • Shops looking to reduce manual measurement and strengthen QA
  • Those interested in shop-floor automation with minimal infrastructure requirements
  • Anyone new to CMM inspection who wants a clear introduction and practical next steps
Quick Vision Pro: Boost productivity with exceptional throughput using CNC vision measurement for fast, repeatable inspection. <Duration: 12 minutes>
As inspection requirements increase and tolerances get tighter, manufacturers need faster, more repeatable ways to measure without adding complexity. In this short webinar, you’ll learn how CNC Vision Measuring Systems improve throughput and consistency while reducing manual effort on the shop floor.
You’ll learn how Vision Measuring Machines can:
  • Measure tiny, densely packed features with high repeatability — ideal for connectors, lead frames, and semiconductor packages
  • Prevent part deformation using non-contact measurement for thin, lightweight, or delicate components
  • Automate batch inspection to reduce operator burden and scale throughput
  • Support larger parts (battery cases, busbars, resin frames) using large-stage models
  • Combine vision and touch probing for efficient 3D feature measurement without repositioning
  • Scan curved or transparent surfaces using a chromatic point sensor — ideal for lenses, HUDs, and reflective materials
Recommended for:
  • Teams looking to improve throughput and repeatability in high-volume inspection
  • Manufacturers measuring small, dense features such as connectors, lead frames, or semiconductor packages
  • Shops inspecting thin, lightweight, or delicate components that benefit from non-contact measurement
  • Quality groups aiming to automate batch measurement and standardize results across shifts
  • Operations needing solutions for both small precision parts and larger assemblies (battery cases, busbars, resin frames)
  • Anyone evaluating vision measurement for the first time or upgrading older systems
FORMTRACER Avant: Combine advanced speed and operability to streamline contour and surface roughness measurement in one flexible platform. <Duration: 42 minutes>
Learn how to streamline contour measurement workflows with best practices for setup, calibration, and data analysis. This session also highlights how the FORMTRACER Avant improves efficiency with faster operation and a combined contour + surface roughness platform.
You’ll learn how contour & roughness systems can:
  • Apply best practices for setup, calibration, and data analysis to achieve consistent, accurate results
  • Identify and prevent common issues such as stylus wear, improper tracing, or inconsistent conditions
  • Improve efficiency using Mitutoyo software tools, automation functions, and measurement workflows
  • Reduce total measurement time with high-speed motion and faster stylus retraction
  • Increase flexibility by measuring both contour and surface roughness in one platform through quick detector exchange
Recommended for:
  • Experienced contour measurement users who want to streamline operations and improve repeatability
  • New users who want to master contour measurement fundamentals and build confidence quickly
  • Quality teams seeking faster measurement workflows and more efficient reporting
  • Manufacturers evaluating a combined platform for contour + surface roughness measurement
MCOSMOS v5.4: Upgrade your CMM software with smarter configuration, enhanced GD&T tools, and automation-ready features to accelerate inspection. <Duration: 52 minutes>
This session introduces what’s new in MCOSMOS v5.4 — including updates that help teams work faster, automate more easily, and improve measurement confidence across lab and shop-floor environments. You’ll see how new capabilities streamline setup, strengthen GD&T evaluation, and improve efficiency from measurement through reporting.
You’ll learn how MCOSMOS v5.4 helps you:
  • Switch between online/offline measurement modes without restarting (smarter system configuration)
  • Stay current with Windows 11 compatibility
  • Improve global tolerance evaluation with expanded ISO/ASME positional GD&T capabilities
  • Enable automation using Mitutoyo Connect for signal input/output setup and operational states
  • Increase measurement efficiency with auto camera switching, probe angle sorting, and expanded repeat-mode options
  • Improve inspection clarity with enhanced visualization tools, including parallel plane evaluation, cone evaluation, and advanced contour fitting features
Recommended for:
  • Current Mitutoyo MCOSMOS users upgrading to Version 5.4 or evaluating the latest features
  • Mitutoyo CMM owners and operators looking to improve workflow efficiency and automation readiness
  • Teams seeking expanded ISO/ASME GD&T capability for global tolerancing compatibility
  • Quality groups aiming to reduce manual steps through smarter configuration and repeat measurement options
  • Organizations preparing for Windows 11 compatibility or standardizing software across multiple systems
Newsletter Registration
Mitutoyo Corporation
Privacy Policy
All rights reserved.
