Do You Use Separate Measuring Instruments for Roughness and Contour Measurements?
-High-accuracy stylus type CNC surface and contour measuring instrument CS-H5000CNC
High-Accuracy Stylus Type CNC Surface and Contour Measuring Instrument Addresses the Following Challenges:
Surface roughness and contour shape cannot be measured without replacing the detector.
I need a system that simplifies the evaluation of PV values for aspherical lenses.
Individual errors persist because measurement points vary between operators.
Challenge: Simultaneous Evaluation of Cross-Sectional Shape and Surface Roughness of Sliding Grooves Is Difficult
Challenge: Setting PV Value Measurement Conditions for Aspherical Lenses Is Cumbersome
Challenge: Eliminating Individual Errors Caused by Deviations in Workpiece Settings
Lens Industry
We offer precision measurement equipment solutions that are useful for shape measurement, an essential requirement for optical lenses that are increasingly utilized in smartphones and other devices.
Bearing Industry
We address the demand for high-precision measurement in the bearing industry, providing solutions that deliver nanometer-level accuracy for the dimensions and shapes of rolling elements.
