Bearing Evaluation
Bearing Evaluation
Bearings play a crucial role in supporting rotating machine parts by reducing friction and ensuring rotational accuracy. As precision requirements for rolling elements continue to advance, measurements now demand nanometer (nm)-level accuracy.
This growing need underscores the importance of specialized measurement technology tailored for bearing applications.
Mitutoyo's Measuring Machines Can Solve the Following Measurement Challenges:
Evaluation of rolling elements such as balls, cylindrical rollers, and conical rollers.
Inner and outer ring evaluation of tapered bearings, etc.
Screw shaft and nut evaluation.
Challenge: Measuring Balls, Cylindrical Rollers, Conical Rollers, and More
Challenge: Evaluating the Inner and Outer Rings of Tapered Bearings and More
Challenge: Evaluating Screw Shafts and Nuts
SJ-410 Series - Compact Surface Roughness Instrument
A compact surface roughness instrument with analysis functions comparable to those of stationary surface roughness instruments. With a wide selection of stylus shapes to choose from, this model supports special forms at a low cost. It can also evaluate minute steps/depths.
