Mitutoyo
Measuring Instrument Overview
What is an Optical Measuring Instrument?
  • An optical instrument magnifies small objects using an optical lens, allowing the magnified image to be observed through a circular screen, eyepiece, or digital display. These instruments are designed for the inspection, measurement, and detailed analysis of small features or components and include systems such as profile projectors, optical comparators, and microscopes.
  • By combining optical observations with a Cartesian coordinate system, dimensions can be accurately determined by measuring points, lines, circles, and plane elements on a flat surface.
Items Measurable with an Optical Measuring Instrument
Key Point: Complex calculations can be performed by combining optical observations with a cartesian.
System Configuration: Profile Projector
System Configuration: Microscope
Benefits of Implementation
  • Being contactless, it allows for the measurement of soft materials and intricate areas.
    ・No deformation in part while being measured or potential markings left behind
  • The enlarged image can be visually confirmed by multiple people simultaneously.
    ・When utilizing a Profile Projector, which consists of a large display
    ・A Microscope with a compatible digital camera interface, displayed on a computer screen
  • Easy to operate by anyone.
    ・The enlarged image can be obtained through intuitive operation.
    ・The contour shape can be easily evaluated by comparing it with a part overlay or DXF comparison in software
  • Various dimensional measurements can be performed by combining optical observations with a cartesian.
    ・Dimensions                    Diagonal dimensions, pitch measurements, angles, etc.
    ・Geometric tolerances     Evaluation (positioning, etc.)
  • Cost-Effective inspection solution with versatility to handle a wide variety of products.
Points to Consider When Selecting a Model
  • Projection system(Profile Projector)
  • Observation system(Measuring Microscope)
    ・Bright field, Dark field, Polarization, Diffrencial intereference observation
  • Machine size and load capacity
  • Projection magnification(magnification of objective lens)(Profile projector)
  • Observation magnification (objective lens and eyepiece lens) (Measuring Microscope)
  • Availability of computing equipment
PJ-PLUS Series - Profile Projector
The PJ-PLUS is a durable, energy-efficient profile projector designed for shop-floor use, featuring LED lighting that resists dust adhesion and prevents mist formation for reliable performance in demanding environments.
PJ/PV/PH Series - Profile Projectors
Mitutoyo profile projectors provide precise, non-contact measurement and inspection by projecting a workpiece onto a viewing screen, ideal for small or delicate parts, surface profiles, and various applications across inspection and manufacturing sites.
QM-Data200 - 2D Data Processor
The Mitutoyo QM-Data200, 264-155A 2-D Processing Unit is a stand-mount model for optical instruments, featuring intuitive operation, automatic measurement identification, statistical analysis, and seamless data export, all designed to enhance productivity and reduce measurement time.
Measuring microscope Lineup
MF-J Series - Measuring Microscope
The MF-J measuring microscope offers rapid focusing in approximately one second, eliminating manual focus variations, reducing operator fatigue, and enhancing efficiency when measuring uneven workpieces.
MF-U Series - Measuring Microscope
The MF-U measuring microscope features an electric vertical motion model with a high-speed autofocus function, achieving focus in approximately one second. This advanced capability eliminates manual focus variations, reduces operator fatigue, and enhances efficiency when measuring uneven workpieces.
Objective Lenses - Embeddable Optical Device
These objective lenses, featuring a long working distance for enhanced usability, are widely used in production facilities for applications such as laser processing and observation, offering compatibility across a broad range of wavelengths, including visible, near-infrared, near-ultraviolet, and ultraviolet ranges.
Mitutoyo Corporation
Privacy Policy
All rights reserved.
