Semiconductor Parts Evaluation
Demand for electronic devices and semiconductor packages is rising, driven by advancements in IoT, automotive CASE, and 5G communications. This growth is accompanied by an increasing need for precise dimensional measurement to ensure reliability.
In 3D packaging technology, which is gaining attention alongside semiconductor thinning advancements, high-precision dimensional measurements are crucial for accurate mounter positioning and assessing RDL lamination deviations.
To meet these needs, we introduce the most suitable models tailored for each application.
Previous Process Applications
A/N MARK (SEMI standard): Width, position, dot diameter and depth
Parts for CVD equipment: Shower head nozzle holes (Inner diameter, roundness, and position)
Parts for CVD equipment: Ceramic heater, silicon ring (Flatness, profile analysis, surface roughness)
Parts for CMP equipment: Polishing pad (Groove width, groove depth, groove pitch, and surface roughness)
Parts for etching equipment: Electrostatic chuck, silicon ring (Flatness, cross-sectional shape, surface roughness)
Post-Process Applications
Lead frame (Width, pitch, height, twist, etc.)
Wire loop height
Lead width, pitch, height variance, clearance
Solder ball height, diameter, pitch
Package board coplanarity
Quick Vision Pro Series - General-Purpose CNC Vision Measuring System
The Quick Vision Pro delivers exceptional performance with versatile models featuring touch probes and non-contact displacement sensors, providing robust support for increased production demands.
Hyper Quick Vision WLI Series - Non-Contact 3D Measuring System
Measuring Microscope
MF/MF-U Series
A highly expandable measuring microscope capable of high-speed electric focusing. Extensive lineup available
Surface Measuring Machine
FORMTRACER Avant Series
A stationary model that pursues high measurement efficiency and safety. By replacing the detector, surface roughness and contour measurements can be performed in one unit.
